Best Amp for Kicker CompR 48CWR82?
TechnoBass
Kicker CXA400.1 - 400w RMS @ 1 Ω
Rockford Fosgate Power T500X1br - 500w RMS @ 1Ω
Rockford Fosgate Punch PBR300X1 - 300w RMS @ 1 Ω
Cerwin Vega HRPM350.1D - 350w RMS @ 1 Ω
There aren't a a ton of 300 watt @ 1 Ω amps these days, seems like your options are either run a 2 Ω woofer or entry level power at 1 Ω is around the 500w range.  No reason you can't get a 500w amp and dial your gains back a bit.  Pretty easy to do with the SMD DD-1, just set your overlap high and you should be good.
If you had a 2 Ω woofer there are some good options out there from JL, Kicker, Rockford and Audio Control.
56 minutes ago, Goomz said:
Or find an 800 ish watt rms amp @ 2 ohms and wire it to 4ohms into the amp. Should be around 3-500 watts @ 4.
Good point, it's probably easier to find amps that will do 300ish at 4 Ω
JBL Club A600 - 350w RMS @ 4Ω
Alpine S-A60M - 330w RMS @ 4Ω
MTX Thunder 500.1 - 300w RMS @ 4Ω
Kenwood Excelon X501-1 - 300w RMS @ 4Ω
Pioneer GM-DX871 - 300w RMS @ 4Ω
Sony XM-GS100 - 330w RMS @ 4Ω
Kicker 46CXA800.1T - 300w RMS @ 4Ω
Rockford Fosgate R2-500X1 - 300w RMS @ 4Ω
CT Sounds M750.1 - 350w RMS @ 4Ω at 12.8v
The list for 300ish @ 4Ω goes on.
Yep and less effort out of the amp and electrical too
instagram.com/installsbypat
  • Who's Online   0 Members, 0 Anonymous, 284 Guests (See full list)
