DallasBass91 Posted July 6, 2021 Report Share Posted July 6, 2021 I have 2 subwoofers both are dual 4’s, if I wire 1 subwoofer in series for 8ohm and the other in parallel for 2 ohm can I then parallel them at the amp? What would my ohm load be? im trying to get the final impedance as close to 2 ohms as possible Link to comment Share on other sites More sharing options...
Dafaseles Posted July 6, 2021 Report Share Posted July 6, 2021 38 minutes ago, DallasBass91 said: I have 2 subwoofers both are dual 4’s, if I wire 1 subwoofer in series for 8ohm and the other in parallel for 2 ohm can I then parallel them at the amp? What would my ohm load be? im trying to get the final impedance as close to 2 ohms as possible If I understand what a friend told me a while ago correctly, even though it'll be a final load of 2 ohm, the subwoofer that's wired lower will still hog most of the wattage, making your subs stay to fight each other basically. But if I understood him wrong, I hope someone corrects me. Here's an idea, if you have the room and can build a new box. But another d4 sub and run 3. It might split up the wattage a little more, but in my experience at least, 3 2000 watt 12's in the right enclosure are usually louder that 2 3000 watt 12's. It all depends on the enclosure though. If the enclosure isn't right, they'll sound like crap regardless. Just a thought... 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
DallasBass91 Posted July 7, 2021 Author Report Share Posted July 7, 2021 1 hour ago, Dafaseles said: If I understand what a friend told me a while ago correctly, even though it'll be a final load of 2 ohm, the subwoofer that's wired lower will still hog most of the wattage, making your subs stay to fight each other basically. But if I understood him wrong, I hope someone corrects me. Here's an idea, if you have the room and can build a new box. But another d4 sub and run 3. It might split up the wattage a little more, but in my experience at least, 3 2000 watt 12's in the right enclosure are usually louder that 2 3000 watt 12's. It all depends on the enclosure though. If the enclosure isn't right, they'll sound like crap regardless. Just a thought... Thanks for the reply, I don’t have enough space for another sub, I’m running 2 18’s in a Nissan Altima wall 🤦🏾♂️ Link to comment Share on other sites More sharing options...
