Wayneausbun Posted August 3, 2021 Report Share Posted August 3, 2021 Need to no what the dementions ill need to make a 4th order bandpass box for one 15 in t2 15d4 Link to comment Share on other sites More sharing options...
jroo Posted August 4, 2021 Report Share Posted August 4, 2021 You will need somebody to model the sub. Might help if you know or show all the TS specs. Once modeled, you can get an idea on size or if the speaker even works in a 4th order. I thought by memory, those subs like big ported boxes, could be wrong Link to comment Share on other sites More sharing options...
stingray72 Posted August 4, 2021 Report Share Posted August 4, 2021 I got the specs running the band pass numbers now. Link to comment Share on other sites More sharing options...
stingray72 Posted August 4, 2021 Report Share Posted August 4, 2021 Nope this speaker wont give you enough ported box space to use the two 8 inch ports youll need to make it work with 2500 rms. Go ported is my suggestion. Like 4.50 to 5 cubic feet net after sub and port displacement tuned to 32 hz with 100 square inches of port area slot port style. Link to comment Share on other sites More sharing options...
