4th order bandpass
You will need somebody to model the sub. Might help if you know or show all the TS specs. Once modeled, you can get an idea on size or if the speaker even works in a 4th order. I thought by memory, those subs like big ported boxes, could be wrong
Nope this speaker wont give you enough ported box space to use the two 8 inch ports youll need to make it work with 2500 rms.  Go ported is my suggestion.  Like 4.50 to 5 cubic feet net after sub and port displacement tuned to 32 hz with 100 square inches of port area slot port style.
  • Who's Online   1 Member, 0 Anonymous, 1262 Guests (See full list)
