Never Enough Bass Posted September 12, 2021 Report Share Posted September 12, 2021 Electrical tape it idk how yours doesn't fit mine does that's weird as shit or take a drimmel to it 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Liljxthexripper Posted September 12, 2021 Author Report Share Posted September 12, 2021 20 hours ago, Never Enough Bass said: Electrical tape it idk how yours doesn't fit mine does that's weird as shit or take a drimmel to it yeah yeah, i thought of that shortly after finishing jamming half in there and hoping it stuck. everything is appropriately done and i have small bass, good to break in still is my excuse. but hopefully soon i can get a battery set up going and i am going to drill out the caps to match the inside terminals. then ill be happy Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 12, 2021 Report Share Posted September 12, 2021 Just pop the caps off and solder it lmao what battery you going for the farthest I've seen my voltage drop to on mine is like 13.7 and that's when it's hitting hard 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Liljxthexripper Posted September 14, 2021 Author Report Share Posted September 14, 2021 On 9/12/2021 at 6:45 PM, Never Enough Bass said: Just pop the caps off and solder it lmao what battery you going for the farthest I've seen my voltage drop to on mine is like 13.7 and that's when it's hitting hard i was told to get a ds3400 as well. so thats going to be my go get. but im looking at a super cap in back. and hell, i set my voltage to output a little under 1k and decided i had room so turned it up just a tad, after adding the bass knob to play it in short spurts and these things are going crazy. less than 1400 max currently and they are steady flexing everything. and whether its the motors or pressure my streeing wheel goes crazy but the door panels definitely give about 2 inches or more Link to comment Share on other sites More sharing options...
