Jonrussell18 Posted September 14, 2021 Report Posted September 14, 2021 Currently running a CES 370 amp alternator. Has worked great for a year now. System is getting bigger and I'm gonna run 2 370s on the same battery bank. Well, I can't get a CES 370 anymore it seems, and I was curious of running a different brand alternator would matter at all. Looking at the JS 370 amp unit to run with my CES unit. Never ran multiple alternators before, just looking for some insight. Thanks in advance!
kalilac619 Posted September 14, 2021 Report Posted September 14, 2021 You’ll be fine…..I currently run a singer and an Autotech alternator with no issues 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
kalilac619 Posted September 14, 2021 Report Posted September 14, 2021 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Arthur79 Posted September 14, 2021 Report Posted September 14, 2021 As long as the voltage output of both alternators is pretty close there shouldn't be any issues. Use a volt meter to check the system voltage with the existing alternator and then check the new one once it's in but before you tie it into the battery bank. If they are off by like an entire volt, you can install voltage regulators to get them matched.
Jonrussell18 Posted September 15, 2021 Author Report Posted September 15, 2021 Nice setup! Thanks for the assurance!
