17 minutes ago, SnowDrifter said:
Power is V^2/R. An increase in voltage is also associated with an increase in amperage, which exponentially affects power. Think of it like water pressure: If you double the water pressure coming out of a hose, you'll also get more flow at that higher pressure.
Simpler way, that takes into account manufacturing error of the amplifier:
Note: Use this only if you don't have access to an oscope/dd-1. It's very dirty.. But better than doing it by some other arbitrary metric, or by doing spreadsheets (especially if the amp in question is over-rated)
1. Play a square wave at max gain (please disconnect your drivers). This will measure the peak to peak voltage of your amp - i.e. the rail voltage. Let's say... You measure 60v.
2. Turn everything down/off. Take that number you just got, and convert to RMS voltage by dividing by sqrt(2). So you'd take 60v/sqrt(2) = 42v
3. Play a sine wave at your desired amplitude (say -5db) and turn the gain up on your amp until your output voltage is 42v. Don't get excited and go higher - that's just clipping.
4. Hook your equipment back up
I get it now I own a dd1+ tho so I just needed to add that to my knowledge bank
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Lol just take your time and read it it'll come to u
06 Charger
Pioneer double din
Xs power d3400
