Level 4 DC Sub Help
MarioD
Hey guys,
So i'm looking to add subs to my truck. I'm trying my best to stuff the biggest subs possible under the back seats. LMI makes a 3.5" lift (the only people going in the back seat of my truck are well under 5'6") and i'm looking to use a subthump tall down firing box. Subthump says the box gives 1.75" of clearance from the bottom of the box to the floor of the truck. I'm sure that's not enough room, but i can't find any info anywhere listing the mounted height of the sub. I need to know the height sticking up, or in this case down, from the face of the box to the top of the surround on the sub. Can anyone help me with this? These subs are perfect for what i wanna do, but if i can't use them due to this limitation, then so be it.
Thanks in advance!
Alright so the sub looks like the surround sticks out in-between a 1/4 and a 1/2 in and it's xmax which is excursion how for it can go 1 way is 23.5mm so it's a little less than a in sounds like it would work
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
