I got a 2019 Acura RDX A-spec and the 3D ELS stock system sounds great but I'm finding it lacks depth in the lower end bass. I have gone through and ready some forums and turned off my surround sound. So the stock subwoofer is an 8" getting 50rms. I had a few options and was wondering if any of these would help me.
The first option is to take the factory 8" out and replace it with a Rockford Fosgste P3Sand run it off the factory amp. I'm not trying to get louder as I mostly listen to volume 10 but want to add more depth.
https://rockfordfosgate.com/products/details/p3sd2-8/
The next option is to add loaded enclosure that has a sub and amp built in a small chassis. Like the kicker hideaway HS10 or Alpine PWD X5 and hide it in the trunk storage area. I would keep the factory sub for mid bass and hopefully I can get lower end depth with one of these. What route is the best and has anyone done or added something like this?
https://www.kicker.com/hideaway-hs10
https://www.alpine-usa.com/product/pwd-x5
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
Your not getting low end because your headunit cuts it off so with the first 1 u don't need a sub u just need I think it's the epicenter or go with the second route
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
I was thinking of changing our my stock subwoofer for a shallow RF PS3 8" and run it off the stock amp. Wouldmdoing that and adding a epicenter improve it?
Yea that would make it a lot better you just have to get something to restore that low end bass manufacturers cut low end bass so it doesn't destroy there cheap ass speakers
06 Charger
Pioneer double din
Xs power d3400
Not sure if that factory amp will power that sub or not you would have to look into that part
06 Charger
Pioneer double din
Xs power d3400
Yeah the sub will be underpowered my factory app does 50 Watts while the sub needs 150watts
Give it a shot worse comes to worse might have to get a little amp to power it the have little amps with small footprints that u can add to it and hide and keep all your space
06 Charger
Pioneer double din
Xs power d3400
Also do I have to disable the ANC in my car?
Adding a different amp yes you will have to disable that but with your factory amp no
06 Charger
Pioneer double din
Xs power d3400
What about adding the kicker hideaway HS10. Would that add more depth to my bass?
