2 06 Kicker Zx 1000.1 Or 1 06 Kicker Zx 2500.1
blkmrideon22s
i just pick up a kicker 06 zx1000.1 with a birthsheet that says it does 1400 watts @ 2 ohms. i plan to find another kicker with the same birthsheet to power 2 fi bl 18. i plan to strap these amps together to get around 2800 watts at 1 ohm. would be better to get 2 kicker zx 1000.1 or just get 1 kicker zx 2500.1?
1991 Ford Explorer 1 Pioneer deh-p4000UB1 Memphis 16-st 20041 Pioneer Premier tsd720c
If i'm not mistaken (and i probably am) the birth sheet is only maximum power output. So you will most likely see 1000-1200 rms per sub. The zx2500.1 (although a current whore) will get you 1250 each per sub
i think i'll just use 2 kicker 1000.1
i'd do just one Kick 2500. hell they are underrated and i'm sure you'll see at least 2600+ from it.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
the birth sheet on my zx2500.1 said 2580 i believe
edit: 2530
Posted Image
i've seen some go up to 2800
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 699 Guests (See full list)
