Subwoofer size & wood
StuntBoy
Building a subwoofer box,ported for a 12” sundown xv.3 sundown. Site recommends  32hz
29” W
16” H
21” D
Does the box specs to be at these specifications that sundown requires? Or can it be a bit smaller of a box or larger?
Also what is better mdf or birch ?
You have plenty of space, sundown box specs are just fine, just pay attention to use correct port area and box calculations to be correct. other than that you want to build the right box for the type of vehicle, on the wood pick 3/4" thickness, wood type between those two will not stop you for completing a project, pick your preference.
I would recommend a double layer for the baffle and heavy bracing all around, the simplest approach is double layering everything but that would result in a really heavy box specially if using MDF.
  • Who's Online   0 Members, 0 Anonymous, 1163 Guests (See full list)
