So I got my alarm installed last night, and the thing isn't working. When I hit remote start it cranks but doesn't catch, 3 times, every time.
When I simply unlock open the door and try to start the car manually (normally) it usually cranks and catches and goes up to its normal 900-1k RMP, then IMMEDIATLY dies. I'm thinking the alarm thinks there's an intruder or somethign??
Astra 4000RS-2W-1 by Scytek
Thyanks guys ... help ASAP would be nice
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
is this for your 98 toyota camry? you may need a bypass
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
Remember when I asked if they offer a lifetime warranty? this is where that comes into play. ;)
The transponder system is more than likely seeing two keys. They probably have the ignition wire hooked up on the 556U or whatever they used... did they ask for a second key to keep up under the dash?
Did it work when you left?
Try unlocking the door with the KEY and starting it also.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
yes sir they did ask for a 2cd key to keep SOMEWHRE idk where they mounted everything .. but i gave them a 2cd master key so they could wire the remtoe start up ... and
YES
i'm happy i have the lifetime warranty theyr'e fixing it 2morow morning supposedly ... my cari s parked at a friends house because i couldnt start it to leave his house last night
if i open the door with the key, do you think the alarm will go off???
and yes the remote start worked when i drove it off the lot ... :(
THANK YOU so much guys, will try everything tommorow morning
~Matthew
