Audiohz Posted March 9, 2022 Report Share Posted March 9, 2022 My 1/0 ring terminals have a 3/8 hole I have seen some people saying to use 5/16 hole terminals. Would this be and issue for the smd fuse holder? I’m curious if I would need to change my ring terminals. Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 9, 2022 Report Share Posted March 9, 2022 All of the SMD fuse holders and speakerbox terminals use a 5/16 nut/bolt. No you wouldn't have to change your terminals due to them having a larger 3/8 inch hole. The fuse holders have a thick piece of aluminum or copper (depending which model you buy) that the fuse and your ring terminal will sit on, followed by a washer then a lock split/lock washer and finally a nut to hold everything down tightly. So there is plenty surface area for a great connection even though your ring terminals have a larger opening. Link to comment Share on other sites More sharing options...
Audiohz Posted March 9, 2022 Author Report Share Posted March 9, 2022 2 hours ago, audiofanaticz said: All of the SMD fuse holders and speakerbox terminals use a 5/16 nut/bolt. No you wouldn't have to change your terminals due to them having a larger 3/8 inch hole. The fuse holders have a thick piece of aluminum or copper (depending which model you buy) that the fuse and your ring terminal will sit on, followed by a washer then a lock split/lock washer and finally a nut to hold everything down tightly. So there is plenty surface area for a great connection even though your ring terminals have a larger opening. Awesome, that definitely adds some great flexibility. Link to comment Share on other sites More sharing options...
