Stock HU distortion
Hello guys ,
Stock HU not sony on ford  with 6.5" front RSX165  gladen , audio control lc2i and 2channel amp. Active sub under seat  us8 gladen .
With oscilloscope play  40hz 0db dist 15/30
                                       1KHZ 0db distortion 20/30
I know that is not right but I start it with 20/30 and set the hole setup.
Continue with 1khz 0db and set the LC2i main output at 5v with DMM
continue with  40hz 0db and give bass output 5v --->to underseat sub.
After that -5 db 1khz to set gain to ampl with crossover to FULL.
Is this the procedure almost correct guys ?
(I know that I must change the HU but not know )  😉
if your radio is distorting at volume 15 with 40hz, than that should be your max volume regardless if volume 20 is clean with 1khz because anything after 15 will always be distorted on your lower frequencies.
Not to mention most factory radio equalization starts to limit or lower the bass frequencies towards higher volumes to protect the crappy factory speakers, so you never want to set gains using a higher volume unless you're running some sort of DSP to fix the horrible factory eq curve, sum the channels together, etc.
  • Who's Online   0 Members, 0 Anonymous, 1114 Guests (See full list)
