riderph Posted May 19, 2008 Report Posted May 19, 2008 if space isnt an issue whats the best box with 2 15's?
hotshot27 Posted May 19, 2008 Report Posted May 19, 2008 too many variables, but i would instictively say a wall. we need some more info. Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
riderph Posted May 19, 2008 Author Report Posted May 19, 2008 these are the subs and amps. 2 stroker 15"s powered by kole audio qx1-2400d - rms power 1800 watts - peak power 2400 watts @1 ohm - strappable technology taking up the whole trunk of the mitsu pajero.. how big should the port be? measurement of box? thanks sirs.
hotshot27 Posted May 19, 2008 Report Posted May 19, 2008 can you measure the actual maximum dimensions for us? we can then help you with some options. Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
01xtreme Posted May 19, 2008 Report Posted May 19, 2008 I think the key to hair tricks is lower frequencies, so you would need quite a bit of power so your subs will move alot of air at low frequencies. My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
PaulO2288 Posted May 19, 2008 Report Posted May 19, 2008 You need to build a box thats tuned low, play a low frequency song, have a box that gets loud, For 2 15"s I wuold make the box around 8 cubes 4 each, test and find out which position is the loudest for your box. What vehicle? Subs back port back is by the loudest other than a wall. Just something to try.
Stephen Posted May 19, 2008 Report Posted May 19, 2008 You need to build a box thats tuned low, play a low frequency song, have a box that gets loud, For 2 15"s I wuold make the box around 8 cubes 4 each, test and find out which position is the loudest for your box. What vehicle? Subs back port back is by the loudest other than a wall. Just something to try. in my car subs up port back is louder you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
PaulO2288 Posted May 20, 2008 Report Posted May 20, 2008 in my car subs up port back is louder What I mean is its the loudest Ive found. Subs up and port back, Its like I dident even hear the bass at all. But every car is different.
