How do you plan on using them? are they mids and tweets?
10 rms 20 peak @ 4 mid or tweet?
50 rms 80 peak @ 4 " "
20 rms 40 peak @ 4 " "
I am assuming they are just raw drivers with no crossovers? which means you would have to have a seperate amp for each set , or an active crossover with 4 sets of outputs one for each set of speakers and use a 2 four channel amps. Because tweets and mids should be crossed over at different frequencies. (not saying your stupid but you said your a noob so I wasnt going to assume you know all that.)
10-20 is 80-20khz full range
50-80 is 5khz-20khz tweeter
20-40 is 40-20khz full range
20-40 is 5khz-20khz tweeter
Clarion ProAudio VRX755VD
Infinity Perfects 6.1-front
Infinity Perfects 5.1 -rear
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
Pair of Memphis tweets
New Build In The Works
Umm since you are new to this I would suggest just getting 2 componant sets that are the same and using them instead because I am pretty certain your not ready for x over building and bi amping. That way you can get a four channel amp that will push the same wattage to each set and call it a day. A lot less wireing and mess.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
could i say screw the tweeter and put 2 full range, two 10/20 's and one 20/40
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
