justinqualls1 Posted May 21, 2008 Report Posted May 21, 2008 I was woundering when running more than one battery is there anything that must be done. I think i read somewhere sometime that you must run an isolator or something. i may be wrong. Just needing a little help from you guys on how to do a multiple battery setup. Thanks
qu1cks1lver56 Posted May 21, 2008 Report Posted May 21, 2008 if i understand right, if its the same battery, you can just wire them up hot to hot and ground to ground, and if theyre different, you gotta have an isolator or something. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
justinqualls1 Posted May 21, 2008 Author Report Posted May 21, 2008 im going to buy all new and same brand and stuff when i buy them i just didnt know about that one thing. thanks for the help
qu1cks1lver56 Posted May 21, 2008 Report Posted May 21, 2008 no problem, thats what this forums here for First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
Kicker Guy Posted May 21, 2008 Report Posted May 21, 2008 if i understand right, if its the same battery, you can just wire them up hot to hot and ground to ground, and if theyre different, you gotta have an isolator or something. Well any battery can be wired to another with nothing else, isolators are only good for running your system with the car off so your starting battery doesn't die. I have heard that if you run 2 different batteries that one will drain off the other one, but I haven't seen anything like that with my personaly experience. Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
justinqualls1 Posted May 21, 2008 Author Report Posted May 21, 2008 what about fuses do i need to have any between each battery?
vexproductions Posted May 21, 2008 Report Posted May 21, 2008 what about fuses do i need to have any between each battery? in all ov my yearz i have neva had to fuse in between bats but u neva know like said b 4 az long az ur main bat haze no drainin problemz u shouldn't have n e probz
dmanson Posted May 21, 2008 Report Posted May 21, 2008 what about fuses do i need to have any between each battery? yes you should have fuses between both batteries, no more than 18 inches after the underhood and to more than 18 inches before the one in the rear. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
