Head Unit with 4 pre-outs. What do I do?
Alright I want to put a 4-channel amp in my jeep. I currently have a Sony mex-n4380bt and it only has a left and right "rear" pre-outs, as well as 2 sub pre-outs.
I'm a car audio nub as of right now. Sorry
I was planning on getting the Skar SKA7EQ and hooking that up, then running the 4 channel from that as well as a mono amp in the future for a subwoofer. Will my headunit work for this? I don't want to deal with using the hi-input on the amplifier. That was my pan originally but reading up on these different eqs has made me want to go that route.
Any help is much appreciated.
My parts list so far is the SKA7EQ and a Skar SK-M400D
The low end solution is using a couple of Y adapters to connect to the 4 channel amp to the head unit but you wouldn't have fader control so the best solution is what you have picked and will work with your head unit no problem.
The high end solution is getting a DSP but honestly for an entry level system that solution is probably not worth it.
Okay sweet, thank you
And yeah I've just got 4 speakers for now. Looking at a 6.5 or 8 inch sub and amp down the road.
Just to clarify then I would use the "rear" rca on the headunit to the EQ
You connect your head unit's  REAR AUDIO OUT outputs to the MAIN-IN inputs of the EQ and you are done.
