PaulO2288 Posted May 23, 2008 Author Report Share Posted May 23, 2008 Imagine takeing your speaker leads and shorting them together. Now take a wire and wrap it perfectly around something evenly then stick an ohm meter on it. More windings more resistance.I'm pretty sure thats how it works. I could deffintally understand it. Thanks! Quote Link to comment Share on other sites More sharing options...
VtecDomani Posted May 23, 2008 Report Share Posted May 23, 2008 Imagine takeing your speaker leads and shorting them together. Now take a wire and wrap it perfectly around something evenly then stick an ohm meter on it. More windings more resistance.I'm pretty sure thats how it works. yip Quote Head Unit: Pioneer DEH-P4050UB Subs: 2 Pioneer Premier 12" ts-w3004spls Sub box: 3.2ft3 tuned to 35hz Sub Amp: SoundMagus DK 1800 Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts Front Speakers: DLS MS5A components 2 gauge power & ground Link to comment Share on other sites More sharing options...
Kicker Guy Posted May 23, 2008 Report Share Posted May 23, 2008 I am not sure exactly, but common sense would look at it like any wire. smaller and longer the wire there is more resistance. but a bigger shorter wire has less resistance. Not sure if thats right but thats my guess. Quote Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz Link to comment Share on other sites More sharing options...
ISO Posted May 23, 2008 Report Share Posted May 23, 2008 Bump! There are more than enough people on here and I'm questioning myself. Someone knows this for a fact. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
