I got 54 cubes
i got the same
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
i got the same
Well it says ported they require 5-8 cubes per.
So I would be able too?
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
you're gonna need a ton of bracing as well as port area and port displacement. you may be able to do three in a line across, but i'm pretty sure two 18" btl on 2-4k each, in a properly built wall, will get plenty loud.
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
I would be physically impossible to do 4 it does look like you could do 3 but 4 just isnt possible at all 3 is cutting it very close to impossible to do
Edited by Aaron813
Alright well i stopped by the shop again today and talked to the owner sum more. And we went out and took sum measurements he took them a lil short jus to b save and he said he thinks he calulated it right and each sub would have like 3.7 or 4 cubs per and i told him that ported they require 5-8per and he said they might be able to do sealed but they still might b a lil under wat they r rated and not having enough airspace with make them more punchier...He said his box specialist had the day off and told me to stop by tomorrow and we'll have him measure just incase he might know a way itll work to get 4.
He told me 2 would be plenty loud and id prolly b hitting in the 155-160db.and said that if it still wasnt loud enough thatthey could make me another faceplate to where i could do 12's or 15's.
Im gonna c if itll work if i have my seats skutted up and door panels removed and maybe even rear deck removed
~REFS~
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
