Never Enough Bass Posted July 1, 2023 Report Share Posted July 1, 2023 Alright so I made this box I have for the dodge charger but now I have a chevy equinox what would be the best kind off box to build Quote 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Joe X Posted July 2, 2023 Report Share Posted July 2, 2023 I guess you could install your current box subs / port up in the trunk of your equinox and see how it goes. Now being in a SUV (larger cabin) calls for larger subs just to try to be as loud as before, say 2 15s subs up port back (2 sa15s for example if you don't want to upgrade power) . that would be ideal, I wouldn't bother to build a new box for 2 12s. Quote Link to comment Share on other sites More sharing options...
Never Enough Bass Posted July 2, 2023 Author Report Share Posted July 2, 2023 2 hours ago, Joe X said: I guess you could install your current box subs / port up in the trunk of your equinox and see how it goes. Now being in a SUV (larger cabin) calls for larger subs just to try to be as loud as before, say 2 15s subs up port back (2 sa15s for example if you don't want to upgrade power) . that would be ideal, I wouldn't bother to build a new box for 2 12s. I wanna upgrade power eventually trying to buy a house first tho was just gonna see what would work till then so even tho my port and subs are the same way I should try and face them up shitty part about that is my smd terminal is on the back so there's a big hole back there Quote 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Joe X Posted July 3, 2023 Report Share Posted July 3, 2023 Not too big of a deal, just cover the hole with some MDF from the inside BUT if the box is a shared port design add an identical piece of MDF in the other chamber to keep volumes identical. Quote Link to comment Share on other sites More sharing options...
Never Enough Bass Posted July 3, 2023 Author Report Share Posted July 3, 2023 (edited) Yea it's a shared port the hole is right in the middle of the box Edited July 3, 2023 by Never Enough Bass Quote 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
