SnowDrifter Posted August 28, 2023 Report Share Posted August 28, 2023 Broken table. Kind of a cool solid 2-pieces-of-wood thing Top and bottom separated. It was originally held together with a piece of plywood - run some screws into the base to hold the plywood, then run some screws through the plywood to hold the top. Screws that were in the base came loose over time and the whole thing separated. Curious if there are any better methods to put 'er back together? I plan on doing some refinishing work while it's apart. Really just needs to be sanded down and polished. I pondered drilling a hole down the center and running some all-thread + bolts through the base, or doing similar but with threaded inserts into the top to clamp it down; but that feels.... Perhaps overdone? Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MrSkippyJ Posted August 28, 2023 Report Share Posted August 28, 2023 Do you need it to come back apart? Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
SnowDrifter Posted August 29, 2023 Author Report Share Posted August 29, 2023 5 hours ago, MrSkippyJ said: Do you need it to come back apart? Yes, but not often Only for moves and whathave you Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MrSkippyJ Posted August 29, 2023 Report Share Posted August 29, 2023 Ah well. I was going to suggest some rather large dowels but they would need to be glued. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
