Help with a sub box
I need help with a sub box. For 2 Orion XTR PROs Dual 4 Ohm woofers.  I can’t find much oh them when it comes too t/s parameters..
box will be going in a chrysler 300 max box space area is around 40 w 43 d x 20 high max
gonna run them at 1500 to 2000 watts so a box that can run lows say 32 to 33 hz plz help subs back port back..
Edited by OuijaEight
Posted (edited)
Features:
  • Diameter: 12"
  • Max Power Handling: 5000 Watts
  • Nominal Power Handling: 2500 Watts
  • RMS Power Handling: 1250 Watts
  • Fs (Hz): 32.3/30.5
  • Qts: 0.59/0.56 (.67L)
  • Vas (cu ft): 1.256/1.198 (.36 cu m)
  • Sensitivity: 84.4dB/83.7dB
  • Mounting Hole Dia.: 11"
  • Mounting Depth: 6.5"
  • Polypropylene dust cap and paper cone is moisture and UV resistant
  • Symmetrical tuned long-throw surround
  • Dual interlaced conex spider
  • Custom cast aluminum frame
  • Tinsel leads stitched and looped across spider
  • Venting in voice coil former is part of the enhanced voice coil cooling system
  • Advanced forced convection cooling system
  • Tri-cooling system
  • Copper wound voice coil on aluminum former
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit before building the real box.
NOTE: Box can still be used with better subs for a future upgrade.
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
