Nickvb6 Posted May 30, 2008 Report Posted May 30, 2008 Every time i see people run power wire to the back of there car to there amps or batts they always run a ground back there to why not just ground it to there body?
pounding hard-Scammer Posted May 30, 2008 Report Posted May 30, 2008 Every time i see people run power wire to the back of there car to there amps or batts they always run a ground back there to why not just ground it to there body? BETTERY current flow when adding a battery to rear cause the chassis cant handle alot of current Im a scamming little cunt rag. i like penis, cum more penis, oh and did i mention penis. i suck at life....
Nickvb6 Posted May 30, 2008 Author Report Posted May 30, 2008 Thax man been wondering that for a wile
mrrairai Posted May 31, 2008 Report Posted May 31, 2008 BETTERY current flow when adding a battery to rear cause the chassis cant handle alot of current Someone on another forum did a test on that and actually running the 2nd ground wire had more resistance than the body itself. Member since 25 Jun 2006 2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
pounding hard-Scammer Posted May 31, 2008 Report Posted May 31, 2008 Someone on another forum did a test on that and actually running the 2nd ground wire had more resistance than the body itself. i was told by pittbulls on onather forum quit awile ago and he nkows what he is talking about...and also steve mead runs a ground wire also actually he runs 4 i think lol Im a scamming little cunt rag. i like penis, cum more penis, oh and did i mention penis. i suck at life....
kentb Posted May 31, 2008 Report Posted May 31, 2008 curious about this too, what if you ground it to the body but use mre wires? will that help? New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
David Posted May 31, 2008 Report Posted May 31, 2008 I did it my jetta build becuase my car is unibody. I came off the alt casing because thats the best ground in the whole car Period.
Derrick824 Posted May 31, 2008 Report Posted May 31, 2008 I ran a seperate 2/0 ground wire straight from the batt to the back in my Yukon and it made ZERO difference.
missinglink Posted May 31, 2008 Report Posted May 31, 2008 I have 1 -1/0 from each alt to frame and 1-1/0 ground per 6 batteries (or side). I just say 1- 1/0 power 1- 1/0 ground 2-1/0 power 2-1/0 ground and so on...May not make a difference but helps me sleep.LOL MLA missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
