as already said safe mode then msconfig. it will work, every windows xp machine on the planet has f8 as advanced boot options, just hold it down if you have to
X2!!
Once you are in msconfig, click on the startup tab and deselect everything that is selected. That should keep that program from loading up. Also will you're in safemode, uninstall any suspicious programs. If you can, download the trial version of this anti-virus/anti-spyware called ESET NOD32. Run it in safemode also.
If none of this works, as mentioned also take that hard drive out and put it in another machine. Unplug the CD rom of the machine you're putting it in and plug in that hard drive. The PC will see it as another local drive. Copy & paste all the data you want to keep off that hard drive on to the drive of that pc. Wipe that drive clean (format it) and start from scratch.
AudioControl
Rockford Fosgate
XSPower
a9cb521a-b3b0-4848-8950-41c45879dd3f_zps
Although holding it too early will likely cause a keyboard error at boot. Tapping it after you see the bios screen should work.
error or not it will still go into advance boot options after you let go it will just beep at you to let go of the key.
thanks a ton guys, another winner for smd!!! saved my ole lady 75-150 on a repair bill to have the pc geeks come to the house and work on it. i was able to do the f8 after the first start screen and enterd under safe mode and did a total system restore and it worked great
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
