well i got metered today at a comp and hit a 138.8 bassrace with 1 12" type R on a 600 watt soundstream 4 channel amp.
is it a good score?? and how can i get louder? i want to hit at least a 140.
right now i have
duralast battery
stock alternator
big 3
2gauge wire
12" type r in 3cube box tuned at 32hertz
soundstream reference 604
NEED TO GET LOUDER!!!
Thats a good score with what you are running.
Congratulations.
Man just start playing with stuff is all I can tell you. Move things around. Make soft things solid and stiffen up things.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Well it looks like you have maxed out the potential of the products you own.
Byron we need to know what kind of vehicle you have first.
All I know now is you can run a 3 cubic foot box.
Unforunetly I wouldn't put much more power on the Type R so thats out of the question and I'm guessing you are useing the biggest box possible for it.
As far as power goes I highly recommend a 1000 watt Class D amp.
1000 wats and the rite sub should get you there.
i did 142 legal on the TL with 2 type-r's off 1100rms, subs were in 2 cubic feet each to 34hz, in my car they peaked at 41. not bad for a truck car. i say get another and a 1000-1200 rms amp
edit:spelling
DC.jpgDC POWER
I want to know if he has the room to fit another sub.
I would try making the box a little smaller like 2 cuft and tunning it higher at about 38hz. I did a 12" Type R in a 1987 Ford Escort hatchback in 2cuft off of 900 watts and it did 144 and change on the dash. It wasn't a trunk car, but I think that maybe 3 cuft is a little on the large size for that sub.
  • Who's Online   2 Members, 0 Anonymous, 854 Guests (See full list)
