Ernesto Posted December 14, 2006 Report Posted December 14, 2006 I know this is a monster battery and it works great for audio but my question is would this be a good battery to replace my yellow top as my main/starter battery (under hood)? Would it be better to run this battery instead of the yellow top? Quote
CUT BUDDY Posted December 14, 2006 Report Posted December 14, 2006 run a hc1400 under the hood Quote TEAM MechMan Alternators
GHOPPOMAN Posted December 14, 2006 Report Posted December 14, 2006 I Replaced my yellow top with the 2400 and am very happy. with the rms i have kinetik says i should have 3 2400s but i only have 2 and am not seeing any sig. voltage drop.....sooo im happy!!! Quote
2000LaDe Posted December 14, 2006 Report Posted December 14, 2006 one hc2400 equals close to 4 yellowtop batteries. Quote
dmanson Posted December 15, 2006 Report Posted December 15, 2006 one hc2400 equals close to 4 yellowtop batteries. i'll have to look into that broham, if that's true then kinetik here i come. i think a HC2400 and a HC800 in the back would do me good. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Ernesto Posted December 15, 2006 Author Report Posted December 15, 2006 one hc2400 equals close to 4 yellowtop batteries. That I know but some people have said they aren't good for cranking up the motor. :-[ Quote
2000LaDe Posted December 15, 2006 Report Posted December 15, 2006 ive had no problems and nobody i know that runs a 2400 under the hood has a problem either. Quote
Ernesto Posted December 15, 2006 Author Report Posted December 15, 2006 ive had no problems and nobody i know that runs a 2400 under the hood has a problem either. Cool... Ima do a little more research before I make it official and swap the Yellow Top for the HC2400. Quote
2000LaDe Posted December 15, 2006 Report Posted December 15, 2006 well for less than a hundred dollars more than a yellowtop. i think its worth every penny. Quote
dmanson Posted December 15, 2006 Report Posted December 15, 2006 one hc2400 equals close to 4 yellowtop batteries. That I know but some people have said they aren't good for cranking up the motor. :-[ i guess i'd better keep researching on that then. i have a dual purpose yellowtop so far and it's only 6 months old and still kicking. but i'd like to know if i have to change it out for sure and go all kinetik. i'd like to do things right the first time versus changing things here and there. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
