Unwanted Noise, What To Do?
Texas Tech
There is a unwanted buzzing noise that comes from my speakers, it is directly related to my RPM's, it gets louder as the RPM's increase and vise versa. What is causing this and what can i do to fix this problem?
Baylor University
Accounting
check your grounds. move to a new spot, make sure all your connections are intact.
- Infiniti QX4 - - 2 Digital Designs 9917s - - Digital Designs Z1 - - Digital Designs C3b -
x2
and make sure your RCA wires are not running with the power wires.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Did you run any of your wiring along with your power wire? cause sometimes the wires will pick up signals and amplify them through your speakers.
1 DC lvl 4 15"
1 Hifonics BXi 1608D
3.2ft^3 Box tuned to 32-33Hz
Knu Kolossus Fleks Kable 1/0
Knu Karma SS 8 Gauge Speaker Wire
Kenwood eXcelon KDC-X493 Head Unit (coming soon)
Kenwood mids + highs (coming soon)
Build
x2
damn, you posted that while i was typing my post :( well x2 what you said ;)
1 DC lvl 4 15"
Build
LOL
alright ill get a multimeter with ohm measuerments and compare grounding spots along with running RCA's on a different side
Edit: Is the RPM's direct relationship with the noise common when this problem occurs?
Baylor University
Accounting
Is this the problem that everyone refers to as "Ground Noise"?
Baylor University
Accounting
It could be the spark plugs interfering with the stereo
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
  • Who's Online   0 Members, 0 Anonymous, 899 Guests (See full list)
