Hissing Noise On Speakers After Hu Install....
so yea whenever i turn on my car and the headunit kicks on the speakers have a nasty hissing noise. as i turn the volume up the hissing noise is drowned out by music. but also when i turn it up i can hear a slight pop as i hit the + button.
so is this just a result of the 20 wrms on my stock speakers? or is it sumthin more serious?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
So have u put an aftermarket HU in or r u still running the amp off the scosche speaker to rca converter thingy
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
I had this through my subs and it turned out to be a ground on the HU... I would check that first.
^^^ wat he said :crazy:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
sounds like a bad ground somewhere . try grounding a rca .if it helps run a ground and solder it to the rca.
if you unplug your rca's when your deck is on will blow your rca's out also and you will get engine noise.
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
i made this lil titorial on how to get rid of ground loop noise and its still workin in my truck, heres a link to it http://www.stevemeadedesigns.com/board/ind...showtopic=15452 its pritty semple to work up and should fix it, it works with my pioneer should work wit ur jvc
ps. only works when usein a ab/2ch mids n highs amp dunno bout speaker outputs on the hu, and u only halfto do one rca thats how i got mine done, good luck with ur prob
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
  • Who's Online   0 Members, 0 Anonymous, 775 Guests (See full list)
