Decaf Posted July 7, 2008 Report Posted July 7, 2008 (edited) So if i were to seperate a pioneer premier 720prs midrange and tweeter what ohm load would each speaker have when using the crossover it would be 4 ohms, but would each be 2 ohm wired in series, or 2ohm mid with 6 ohm tweet? or both 4 ohm wired in some mysterious way that doesnt change impedence? edit* im going to wait to buy a 4channel amp but until then... i have a jvc shx-8500 which is 35w rms x 4 @ 4 ohms digital class t internal amp it has front hpf 1.6khz-16khz @6,12,18 db and rear lpf 31.5-200hz @ 6,12,18 db and hpf 1.6khz-16khz @ 6,12,18 db so if i found component set rated at ~75w rms, could i not use the crossover and use the deck instead since itd be active instead of passive Edited July 7, 2008 by decafcappucino Quote
David Posted July 7, 2008 Report Posted July 7, 2008 use your DMM and check the resistence and you should have your answer Quote
Decaf Posted July 7, 2008 Author Report Posted July 7, 2008 i know im a lazy man this evening... has anyone ever checked with a dmm to see what their components read? Quote
Decaf Posted July 8, 2008 Author Report Posted July 8, 2008 bump for a answer... anyone ever check ohm load on component set to see if both tweeter + midrange read 4 ohms on a 4 ohm component set? Quote
deafyT Posted July 8, 2008 Report Posted July 8, 2008 i know im a lazy man this evening... you expect us lazy bastages to help out your lazy ass? it took more effort to bump this thread 3 times than it would to put the twinkie down and test that chit. Quote ((((((((((((((((((((((((((((((((((((((((((((((((((((in stereo))))))))))))))))))))))))))))))))))))))))))))))))))) team audio thugz uuUhhHhhHhh. straight ghanxstuh since 2007.
Decaf Posted July 8, 2008 Author Report Posted July 8, 2008 (edited) if i had that component set... dont have one yet now do ya dig? i checked my stock speakers in grand am and tweeter was 6 ohm wired in parallel with 4 ohm mid in door.... but thats not a component set soooo bumpage! Edited July 8, 2008 by decafcappucino Quote
deafyT Posted July 8, 2008 Report Posted July 8, 2008 [no], i'm too lazy to care. Quote ((((((((((((((((((((((((((((((((((((((((((((((((((((in stereo))))))))))))))))))))))))))))))))))))))))))))))))))) team audio thugz uuUhhHhhHhh. straight ghanxstuh since 2007.
Decaf Posted July 8, 2008 Author Report Posted July 8, 2008 obviously so says ur dont give a fuck meter lol Quote
Decaf Posted July 8, 2008 Author Report Posted July 8, 2008 does anyone else give a fuck? help a brotha out Quote
