Question About Ohm Load For Components...?
So if i were to seperate a pioneer premier 720prs midrange and tweeter what ohm load would each speaker have
when using the crossover it would be 4 ohms, but would each be 2 ohm wired in series, or 2ohm mid with 6 ohm tweet?
or both 4 ohm wired in some mysterious way that doesnt change impedence?
edit* im going to wait to buy a 4channel amp but until then...
i have a jvc shx-8500 which is 35w rms x 4 @ 4 ohms digital class t internal amp
it has front hpf 1.6khz-16khz @6,12,18 db and rear lpf 31.5-200hz @ 6,12,18 db and hpf 1.6khz-16khz @ 6,12,18 db
so if i found component set rated at ~75w rms, could i not use the crossover and use the deck instead since itd be active instead of passive
Edited by decafcappucino
i know im a lazy man this evening...
you expect us lazy bastages to help out your lazy ass? it took more effort to bump this thread 3 times than it would to put the twinkie down and test that chit.
((((((((((((((((((((((((((((((((((((((((((((((((((((in stereo)))))))))))))))))))))))))))))))))))))))))))))))))))
team audio thugz uuUhhHhhHhh. straight ghanxstuh since 2007.
if i had that component set... dont have one yet
now do ya dig?
i checked my stock speakers in grand am and tweeter was 6 ohm wired in parallel with 4 ohm mid in door.... but thats not a component set soooo bumpage! :clapping:
  • Who's Online   0 Members, 0 Anonymous, 1451 Guests (See full list)
