Can't speak for the other amps, but I can for the Autotek.. GREAT AMP! ;) it will give you what you ask for, Just have the power it asks for!
Relatively speaking, these amps are supposed to not be that power-hungry though, right?
I contacted Maxxsonics just to make sure I was correct, here is the reply.
The MM4000 is very efficient for an amp its size. The XX Cyclops is a 4000watt amp that is a little more "power hungry" than the MM4000. :D
I hope this helps a bit.
48956a0.jpgwww.competitionsoundz.comTeam R&RTeam MaxxsonicsTeam DC AudioTeam PowermasterTeam KinetikHooker car audio
Okay here is what i have.
Stock alt
Stock battery
1 little Kinetik HC800 in the back.
All of this is powering
1 MM4000
1 MM100.4
about 8 neons
5 tv's
AC
HEAT
And i have only had an issue once where my MM4000.1D drained my HC800.
I know i need to upgrade my batteries, i just have not gotten around to it.
And i have had this install for about 10 months now just like this.
So no the Autotek MM4000.1D's are not power hungary.  But I do suggest to give more then i am hehe.
The autotek peaks at a 3 ohm reactive load
Tested to do 4200 @ 12 volts @ 3 ohm
I hope this helps
