david you are wise, and yes that dose make some common sence now that i think of it. smaller then rec. would make it like a sealed. will have to try that next system i build.
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
simpe way to think of it is,
the more the cone moves, the more effecient the cooling process of the woofer motor/coil is
small box, and the woofers barly movong, them coil winding gonna get red hot, then snap, or slinky
cone moves to far, in and out, and you start getting some rattling or popping noises, gonna have to roll the gain back a tad till mechanical noise goes back down
yeah you really have to be carefull either way you go with High powered Systems.
Big Power +big box+ ignorance= tore up spiders, bottoming out the woofer, tinsle lead slap and more.
Big Power+ small box + ignorance = burnt coils, slinkied coils, stinky woofers.
both will kill a woofer if your not smart.
aslong as your smart about it you should be ok.
like start smelling the woofers you gotta back off the volume
just use common sense and everything should be ok
