Alright guys I have a 08 tahoe with a stock battery. I have a JL 1000/1 hooked up to a JL W7 I have a 100 watt circuit breaker hooked up and when it hits hard the circuit breaker pops this is driving me crazy. I have replaced the circuit breaker already. I have 4 guage wire running it all. Any suggestions or advice. Should I get a kinetic power cell or a yellow top battery. It only happens when I hit really hard with the bass knob turned up. It will play at low volumes well. Please help me out before I pull out my hair.
You might as well pull your hair out because if you knew enough about car audio you wouldn't have the bass knob all the way up, or have a circuit breaker.
Thanks for your help.
WOW I don't think you know what you got your hands on.
That is a very current hungry amp.
You are not setup to run that thing propperly.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
What do I need to run it? I have a kinetic power cell, should I use that and maybe run 0 gauge wire and a yellow top?
I have already had one of those and it blew them as well. I meant t say 100 amp circuit breaker.
then go with a 300 amp fuse
94 3000gt
18" Kicker Solo X
KX2500.1
2 KX350.4
8 JBL Coax Speakers
250A Mechman Alt
Well rite off the bat you need 1/0 guage wire.
I recommend doing the Big 3 as it has been a proven method for better current transfer.
http://www.stevemeadedesigns.com/board/ind...showtopic=13280
Then put a deep cycle battery in place of the starter battery.
That should solve your problem.
Go 150 amp on the circuit breaker.
I would atleast do a 150 amp fuse or circuit breaker, if its true 4ga wire it will take it. Best would be get 0 ga wiring
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
