Got some stock s10 tails off a junker.
I cleaned them up some, but not perfect. Enough to get a good idea of what i was working with.
Anyways, after several mixes, about 7, I finally got a batch of paint I was happy with.
Here are some pics of the tails painted...................
The one on the left.....the very center strip is the stock tail color. The bottom is mix #5, and the top is a mixture of mix #6 and mix #7.
The tail light on the right is mix #7.
Building The Best.....Repairing The Rest
The bitter after-taste of a poor quality job will last far longer
than the sweetness of that cheap price!
Now here are some pics of them plugged into Ryan Jimmy as my test truck.
Now it has 2 bulb holes, I used 1. And I didn't do the reverse lights.
This is just the brakes on in the day. Sorry about that annoying glare.
In comparision to Ryans stock tails........
Last shot of them in the dark.
Again, this was just 1 bulb.............
Pretty happy with the results. I think this is more durable than the VHT Nightshade spray. And with the clear coat, it is polishable.
not bad bro....i like it...
but y didnt you just pick up some nite shade spray tint....that is made for the tails and such?
just a thought
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
The VHT stuff is ok for 1 coat. But if you don't get the right coverage the first time, and you try a second coat, it tends to cloud up.
And then it has a chalky texture to it sometimes.
I use standard automotive paints and clear coat. A couple layers, some wet sanding and buffing and you have a gloss finish that is durable.
Sure, it is more expensive, but it is beter IMO.
Look killer. What kind of paint? Candy or translucent?
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
Ford black base coat and a clear. Just had to play with the mix ratios to get it transparent.
Could do a kandy, but that cost more money. So i found a ratio that works as good using standard base blacks.
Cool, Never thought of that. As I said, looks killer.
ahh....icic....like i said i was just wondering....they look great tho....good work!
Wiring-Memphis
hay what interior plastic do you have for 97 extra cab same color as the dash peace i got from you. I need a speedometer to.
