javy101 Posted July 12, 2008 Report Posted July 12, 2008 Have you guys had any experience with the 2500.1 cuz i was wondering what kind of power does it put up on say a normal 14.4 v system
Kicker Guy Posted July 12, 2008 Report Posted July 12, 2008 2500+ depends on the amp.... I have seen a lot in the 2700's and some as high as 3k. Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
Boon Posted July 12, 2008 Report Posted July 12, 2008 You have a dual 2 ohm BTL. The 2500.1 isn't 1 ohm stable except maybe for burps. 10.x volts fo' life!
Tub Asko Posted July 12, 2008 Report Posted July 12, 2008 You have a dual 2 ohm BTL.The 2500.1 isn't 1 ohm stable except maybe for burps. i ran it at 1 ohm for about 3 min on a pair of 12" cvxs. It wasn't seeing much because my voltage was at 11. The problem with the zx is that it is 2500 at 14.4. To see that optimal output you have to feed the beast and it's VERY hungry Facebook Youtube Murdered '07 Silverado
hotshot27 Posted July 12, 2008 Report Posted July 12, 2008 i wouldn't run it at 1 ohms, it may take it but why risk it. and it you have dual 2, then this prolly aint gonna be your amp Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
