Today i went on a little drive and i was playing music for about 1hour & 15min not full tilt but i was pounding a little, then my amp shutdown so pulled over & the amp was very very hot. What can i do to keep it cooler. Help :search:
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
blow on it like ramen noodles.....
j/p get some computer fans and mount them so they blow cool air across the amps :)
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
How big & how many
MLA module 15+volts
Team Bass Hz
Just curious have you been checking your voltage drops while playing that large of an amp?
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
A pic of how the amp is mounted would be helpful.
The lowest i have seen it is 12.2, when it gets that low i turn it down for a while. I only let it go down that far for a couple of seconds at the most
MLA module 15+volts
Team Bass Hz
The amp is between the back door & the subs box, not very much airflow in the back because the box is so big
MLA module 15+volts
Team Bass Hz
I'm no expert but you need to get over 13 volts.
The more voltage = less amperage = less heat build up.
An amp that big I imagine you don't have alot of mounting options.
I would get a few fans and try and get your voltage up.
