hello,
i just going over to 4 18's fi btls
ive everything now,
4 18'' btls
8 RF t4000bd's
what kind of box will you advise to fit this.
before i was running 2 18'' en 4 t3000bd's
now ive more than double the power en double of woofers.
what kind of box enclosure do ya think will be the best for this instal ??
im used to walls, but boxes like meades tahoe are also nice.
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
Your running 8 t4ks to 4 btls? So one per coil? Your box better be strong as hell then and small as hell to support the subs suspension on that kind of power. what kind is up to you and the vehicle its going in. Is this for farts or music?
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
is coming in a van, and is for music, a daily driver, and yes 1 amp a coil
OWJEAH PICTURES OF THE EQUIPMENT ARE COMING SOON
well I would do a wall 4 inches thick 1" mdf sandwiching 2" of concrete and then build the side and rear walls the same way with allthread or steel reinforcing if it was me. But in a van definately dont do a crx style box unless you plan putting it all the way to the rear like in a s.u.v. But i wouldnt even do that vans are made to wall off and that is the sole purpose they are made for. :D
Scientia est Vox
owjeah and i offert a lil bit to early cause i just got the old btl's :S but when they were on the way the new one came out :(
but this the setup of the btls i got.
double 2 ohms
spl
universal
high x mal coil
5 spider config
just wall like ive now in my toyota with the 2 mt's ??
probably i gonna link them all 8 to gain them more easier
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
