My bud has a recent model crunch amp, the power wire shorted with some metal on the seat and now he says that one channel doesnt work and the other channel works, but puts out a bad buzzing noise through a sub thats hooked up to it.
he looked inside the amp, he tested out every MOSFET to see which ones weren't reading anything. he found 4 MOSFETS that didnt read anything, they had this stamped on them, "mospec F12c20c A9D". The model number is F12c20c i'm guessing.
i cant find that MOSFET's anywhere. Show me some reputable sites where i can find it.
thanks - Steve
Edited by Krannyman92
Those are not mosfets they are diode packs.
1975 Oldsmobile Omega SalonStill Under ConstructionTeam Sound QubedTeam H-O Alternators / Team Kinetik AudioR.I.P Team US Amps
WHOOOOOOAAAAAAAAAAAAAA HOLD THE FUCK UP!!! I know your honey bun smugglin ass aint talking shit!
Diode packs will read one direction but not the other and one way will be a short the other open.
I would check the outputs the 4 bigger devices again. measure from tab on part to each of the outer legs if either of those shows a short or close to it replace it.
Pull those tie-down bars and take a clear pic and post it.
Edited by USAMPFREAK
so for the 4 black diode packs, measure the outside legs to see if they arent shorted out. if they are replace them.
but i cant find any of those diode packs, its so hard.
says the amp tech
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
im the owner of this old amp...where is teh tie-down bar at on the amp..thanks mike
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
says the amp tech
Damn it rusty dont blow my cover here.
what cover? :zorro:
whats the "4 bigger devices" you talked about, the FET-looking things on the right side?
