1998 Camry Re-build (box Pics 9/27)
alt arrived!! looks BEEFY will get pics soon :) installed 2morow!!!
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
Got it installed. ..shit SLAPS louder for sure. and i ge ZERO voltage drop (did big 3 in 1/0 today)
it chills at 14.4 or 14.5, and goes down to 14.1 at the lowest (usually nothing) it is legit ....
ProbleM:
My sub after about 5 min of HARD playing gets stinky a little bit and is hot (the dustcap) to the touch. my gains are at 1/3
what should i do? is it clipping?
i'll et pics and a vid for suret his weekend
~Matthew
Thats wierd gets stinky... In your vid doesn't even seem like its flexin that much... Does it flex pretty good and the vid just doesn't pick it up or is the vid pretty accurate? Also my opinion on the volt meter is hook it up to the straight to the battery.. And if you using a back battery(which i dont see in your sig but..) wire your volt meter to the back battery so you always know what voltage your amp is recieving..
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
any time you give a woofer more than rated power, you run the chance of running into problems. the box is right inline for rms of the woofer per Rusty.
5 mins at full tilt or near full tilt, with more than rms, you can and will get a lil smelly, just ease off the volume a lil bit and you will be fine, no system can run full tilt or near full tilt continously.
1/3, 1/2, 7/8 gain level doesnt matter as long as it was set to your rca's output.
Thats pretty fast 5min. Usually even if its slightly over its rms it can play longer than 5min without getting hot/stink.
the sub is only rated at 1kw and he is giving it 1500 in a box designed for lows and 1kw, doesnt sirprise me at all that it gets stinky.
Wow those lvl 4's are only rated 1k? So the lvl 5's are 2k im guessing? I was thinking higher but guess not. The amp is doing 1.5k according to his birthsheet or his own test he shows hes getting 1.5k at the sub.
Car Audio + Bodyboarding/Longboarding = LIFE!!!
good news. just making sure i wasn't clipping it too bad ... i turned the gain to in between 1/4 and 1/3 now
not as loud, but it doesn't get AS stinky AS fast :)
i'ma go take pics, brb
~Matthew
the lvl 4 can take more power if it has the level 5 coils,idk if he did this didnt c if he did or not but with level 5 coils it should be able to take 1.5kwrms clean power.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
Clipping too bad? Maybe use an o-scope to make sure its not clipping at all possibly?
  • Who's Online   0 Members, 1 Anonymous (See full list)
