DUBIE Posted July 19, 2008 Report Share Posted July 19, 2008 now i got problems starting my car sometimes..could any body help me out on diz?? Quote Link to comment Share on other sites More sharing options...
E a r t h Posted July 19, 2008 Report Share Posted July 19, 2008 Need to know what you have and what you did Quote Link to comment Share on other sites More sharing options...
DUBIE Posted July 20, 2008 Author Report Share Posted July 20, 2008 i got 2 amps...(1)600 watt for mids and highs..(1)1000 watt amp for 2 "12's".....i did the BIG III..but before i did the BIG III or had my system my car already had that problem....could it be the cable from the fuse box, the starter,the battery,fuses..??? Quote Link to comment Share on other sites More sharing options...
E a r t h Posted July 20, 2008 Report Share Posted July 20, 2008 Did you check your battery state of charge? If you here a clicking sound when you attempt to crank the engine ( ignition start position ) the battery is the problem, so check it. It sounds like machine gun dry fire, tick tick tick tick tick. If you're not having this problem lmk Quote Link to comment Share on other sites More sharing options...
jmsonoma03 Posted July 20, 2008 Report Share Posted July 20, 2008 i got 2 amps...(1)600 watt for mids and highs..(1)1000 watt amp for 2 "12's".....i did the BIG III..but before i did the BIG III or had my system my car already had that problem....could it be the cable from the fuse box, the starter,the battery,fuses..??? starter did you run a new wire to the starter?? double check al wire connections esp the fuse box if its loose you might be loosing power to some importent(sp) circuits. Quote Link to comment Share on other sites More sharing options...
DUBIE Posted July 21, 2008 Author Report Share Posted July 21, 2008 starter did you run a new wire to the starter?? double check al wire connections esp the fuse box if its loose you might be loosing power to some importent(sp) circuits. naw i jst added a 1/0 gauge wire to the alternator goin to the battery..but maybe it might be the fuse box cable...its very very white...u knw wut i mean?...i think ima change it....would a 2 or 4 gauge cable b good??? Quote Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted July 21, 2008 Report Share Posted July 21, 2008 (edited) verry white as in hot or white as in crossion? cause if its that hot somethis shorted out bad, but put a fuse in line with ur alt, 150amp-200amp no more than 200 i dont guess if ur alts bigger, and did u upgrade the ground from the motor to the chasis and from bat neg to body? if not then ur tryin to push to much current into the batt but not let it flow right so it aint chargeing efficently, but on the not wantin to start right all i can see that might be wrong is a bad ground, bad battery or a short somewere Edited July 21, 2008 by tacomabanga1986 Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
DUBIE Posted July 21, 2008 Author Report Share Posted July 21, 2008 verry white as in hot or white as in crossion? cause if its that hot somethis shorted out bad, but put a fuse in line with ur alt, 150amp-200amp no more than 200 i dont guess if ur alts bigger, and did u upgrade the ground from the motor to the chasis and from bat neg to body? if not then ur tryin to push to much current into the batt but not let it flow right so it aint chargeing efficently, but on the not wantin to start right all i can see that might be wrong is a bad ground, bad battery or a short somewere its white like old...like idk how to say it...or like u said "WHITE AS IN CROSSION"..... Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted July 21, 2008 Report Share Posted July 21, 2008 its white like old...like idk how to say it...or like u said "WHITE AS IN CROSSION"..... The corrosion is preventing the current from getting to the starter. A starter motor is the highest draw in the vehicle, (up to 500 amps sometimes) and will often be the only thing that doesn't work well (everything else electrical on the vehicle will still work OK) Clean off all of the corrosion with a wire brush, then in stall new, clean battery cables and ground straps and it will start like new. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
DUBIE Posted July 21, 2008 Author Report Share Posted July 21, 2008 ok....today i cleaned the battery wires and upgraded the fuse box/relay wire in the hood...and nothing changed at all...the car is still the same...!!UGH!!.....anybody know anything else that could help me out? Quote Link to comment Share on other sites More sharing options...
