And if i tried that would it have bad results?asking cause i already bought a sealed box but now want sum ports?
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
i would doubt its a good idea.. usually a ported box would be a bit bigger then the sealed on the same subs, if its within the ratings of the manufacturer it should be ok
what subs and how big of a sealed box you got?
never mind i see you have soundstream 15's.. they would probably need a bigger box for sure ported, i wouldn't just add ports just build a ported box you would be much happier
Edited by RatBass1998
15" LMS Ultra
AB VFL 200.1 3kw+ rms@ 1 ohm <-- 500.1 in near furture
3.5 cubes at 34 hertz
2 Exide Orbital's
200 Amp EA Alt
125 sq ft BXT
believe me i would build it,but shop is charging 350,another one is 250,that's money that i do not have.and me well i cant build really good and i dont have any tools in order to make anything really.
i bet someone on either here or roe would build you one way cheaper then any prices you said, i just don't wanna see you fry your subs
edit: i sold two 15w3's to a good buddy of mine, we built him a sealed box for his trunk it sounded great and did well.. he called me a week later and said he wanted his money back one of the subs fried and the other sounded horrible, and thats what he did he just added two aero ports to this box and poof
15" LMS Ultra
2 Exide Orbital's
200 Amp EA Alt
125 sq ft BXT
Then stay with your sealed box or ask a couple of your friends if they have tools....building boxes isn't something your just automatically great at (unless you did woodworking before) you gotta try and try agin you'll get better eventually.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
well do you know anybody that will do it?i have them in a 2001 pontiac grand prix?and he added the aero ports on a sealed box and messed up teh speakers?
my friend might have tools,but say i do build a box what materials would i need in order to make a box?
Well heres what typically happens you take a sealed box which is typically much smaller than the ported spec you add aero ports and you end up with a tuning extremely high (50hz+) and when I tries to play a low note it unloads the driver or the box is too small the cone can't move enough to cool the VC and it end up smoking the coil.
My YouTube Videos
-glue
-screws
-enough mdf/birch (NOT PLYWOOD/OSB)
-carpet/paint
-possibly resin and glassmat**
-some 2x4s or threaded rod (for bracing)**
**Note: not required but a good idea if the box is large.
My YouTube Videos
so im pretty much better off with the sealed box for now.hmm thanks i learned something new today :) .but say i do build a box what materials would i need in order to make a box?
