what do ya mean by "other harness"? i never knew there was 2?
Eclipse cd7000
i just went out and looked in the garage, i think i have the clip you need right here in my hand.. i'll check 2marrow after work and make sure it fits and is the right one and i can send it to you, just pay for the shipping.
i hooked it up for one day till i ran my own speaker wires and unhooked my factor amp.
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
if im not mistaken, its the harness for the Premium Sound. which im thinking you have.
ROE Ref's-
SMD Ref's-
CAC Ref's-
OK...thanks and sounds good just lemme know...Ill have some pics 2nite of what clip im talking about...I think its 16 wires...8 on top and 8 on bottom
Eclipse cd7000
well you can either take the one back and try another like i did, or buy the other harness, or run your own speaker wires and just unhook the factory amp.
Or bypass the factory amp. On my Explorer (It's a 96 XLT, but they're basically the same vehicle), when I wired my Pioneer into it, I had an extra wire on my adapter that plugged into the factory wiring, it was the turn-on lead for the factory amp. Just wire it into a ignition hot lead.
Then down the road when I installed my amp, my dad ended up making a bypass for the factory amp for me. Just find the connectors that go into the factory amp for the pre-amp and post-amp side, wire them together and plug them into the wiring for the car.
Also, please don't ask where we got the wiring to do the amp bypass. My dad works for Ford, and he got it from somewhere
there are three differrent harnesses for them fords you just got the wrong one if you are just addind a deck and dont care about sound quality get the right plug and wire it up if you want it to sound right i would bypass the factory amp just run four speaker wires to the amp and tag onto the outputs. the amp should be in the rear passenger 1/4 panel.
  • Who's Online   0 Members, 0 Anonymous, 733 Guests (See full list)
