Alrighty here....im buyin two Fi btls from Exposport. They are D1 so im tryin to figure out an amp that will actually PUSH them. But i need to do it with one amp because I really dont wanna put my electrical through .5 ohm stress. So im lookin for ideas of an amp that is like 4000 TRUE watts rms or more to really make these btls push. Im lookin to spend about 800 bucks if possible. Maybe a little more. If you got any ideas lemme know guys...thanks.
**New setup in the works** Shocker sigs ftw!
*Breakin Glass and Kickin Ass*
Team SBC
Team Full Force
Refs
SMD-derrick, Bangin Explorer, Exposport, Bass 14
CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14
cac.org-Spl Guru, Andrew, dblover, lunari
yeah...thats the problem is $$$ i was actually thinkin bout the kickers too.
Team SBC
Team Full Force
Refs
Do the autoteks have true wattage?
Team SBC
Team Full Force
Refs
the higher end ones are pretty much true watts with good electrical, but avoid the lower power models [same situation as crunch and 3000D and lower crunch models]
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
i might be investing in an autotek then : ) any other opinions?
Team SBC
Team Full Force
Refs
Posted (edited)
Autotek years 92-2000 Good!
mm4000 is pretty much going to be hard as hell to find
The new newer Autotek amp line I cannot comment on because I havent used any of it Except for the SX900x and it was decent.
800 bones for that kind of power is going to be very very hard to find, Unless you can get a good used amplifier that wasn't totally beat on I would just spend the money to buy a new amplifier.
Just my thoughts.
Might want to give this guy a PM this is a solid amp http://www.stevemeadedesigns.com/board/ind...showtopic=25819
Edited by Shinju
