audioman21 Posted July 25, 2008 Report Posted July 25, 2008 Can some one let me know if this electrical setup will support my install? Should I step anything up? 140 or 160 ho alt..(don't have yet)....Yellow top under the hood. One run of pos. and neg. 1/0 gauge Knukonceptz KLM wire to trunk. A Powermaster D925 in the trunk. The setup this will be running is two Elemental Designs ED Nine.1(1200 watts rms at 1ohm each), and a two channel amp thats approx. 100x2(undecided on this amp)
fourlug Posted July 25, 2008 Report Posted July 25, 2008 That should be fine, but what size is your wire (1/0?)
Guest Posted July 25, 2008 Report Posted July 25, 2008 run a bigger battery in the trunk, either a D3100, 9a31, or hc2400. everything else is fine. edit: yes it is 1/0. do the Big 3 too. then you shouldnt even have voltage drops, if so, very little.
audioman21 Posted July 25, 2008 Author Report Posted July 25, 2008 So one run of each in 1/0 gauge should be ok?
MECHMAN Posted July 25, 2008 Report Posted July 25, 2008 So one run of each in 1/0 gauge should be ok? Yes, as long as it is high quality wire. Make sure that you ground to either the same side frame rail, or the same side sub-frame if it is a unibody vehicle. What kind of car is it? 1-888-MECHMAN www.Mechman.com [email protected]
audioman21 Posted July 25, 2008 Author Report Posted July 25, 2008 1996 Cavalier. I know over kill is always better but I was wondering if I can get away with one run of positive and one run of negative.
