96saturnsl Posted July 31, 2008 Report Posted July 31, 2008 ok i have a box design for my bl 15 and i need the port calculated, needs to be 35hz...but it has to be partly in the box and sticking out so it can go into my rear armrest. if someone can help me with this it would be appretiated.
babyjoker Posted July 31, 2008 Report Posted July 31, 2008 post the box specs, more info is needed for others to help 1999 Eclipse N/T 12'' Fi BTL Gp3000d PM D3100
96saturnsl Posted July 31, 2008 Author Report Posted July 31, 2008 post the box specs, more info is needed for others to help 4.036 cu ft 12 height 22 bottom depth 19 1/4 top depth 30 width needs to be tuned to 35hz, its a 15 BL
96saturnsl Posted July 31, 2008 Author Report Posted July 31, 2008 4.036 cu ft12 height 22 bottom depth 19 1/4 top depth 30 width needs to be tuned to 35hz, its a 15 BL no one has a clue how to do this?
96saturnsl Posted August 1, 2008 Author Report Posted August 1, 2008 ? at least give me a formula to figure it out?
audiofanaticz Posted August 1, 2008 Report Posted August 1, 2008 4.036 cu ft12 height 22 bottom depth 19 1/4 top depth 30 width needs to be tuned to 35hz, its a 15 BL are those inside measurements our external measurements. what is the thickness of the wood.
96saturnsl Posted August 2, 2008 Author Report Posted August 2, 2008 are those inside measurements our external measurements.what is the thickness of the wood. external, 3/4 mdf
