im running 6 sub amps and 2 highs amps .....
do i need to upgrade my remote turn on .. and do i need a line driver iv got a $200 alpine (its decent but probly low voltage??)
what do you guys think if and if i do need these where can i get them??
thanks alot
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
I would deffinitly use a relay on your remote wire with that many amps, line drivers can deffinitly help, especially if your head unit is only a 2v pre-out
thanks man got ne ideas as to where to find em ... or where you recomend ?
oh and i dnt think i ever got back with you you had left a comment on my build a while back .... thanks for looking at it bro .. it means alot to see you guys...."the big dawgs" looking at my build, but thanks man
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
yeh a good line driver would definitely help. look into the Rockford Fosgate 360, 360.2 or look into just about anything made my audiocontrol. it would definitely make your music sound crispier and cleaner.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i kno i just need to look into these but .... whats the difference ? and are certain 1's for highs/mids and certain ones for subs or does one have both....
and on the line driver do i just boost the first input into my #1 sub amp (b/c they are all linked off the amp out)
i called maxxlink they said it doesnt work with 6 only 4 or 5 amps
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
hit up kingsuv with the maxxlink question. i though it ran up to more amps than that. i know you can run maxxlink to maxxlink though. as for the line driver. i have an audiocontrol 3.1 (or look into the Overdrive) and that does me good, others may suggest the RF 360 and 360.2. go to www.audiocontrol.com or www.rockfosgate.com and read up my brotha. with that many amps a good line driver or two will do.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
alright thanks man....
and one other ?
i can just use a 12v for my rem turn on right ??? like a 12v seleniod with the true rem from the deck to activate the seleniod??
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
ISO gave me some real good advise when I got my line driver, and I LOVE it!
Pheonix Gold TLD22 $29.99 at Sonic Electronix
http://www.sonicelectronix.com/item_13857_...Gold+TLD22.html
Excelent Line Driver!
Boosted my 2 volt signal to 8 volts!
thanks man checkin it out rit now mane might get it
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
will adding a line driver to a 2 volt pre out HU make the sub louder? i'm not EXACTLY sure what they do but i have a pretty good understanding
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
