I have been getting a lot of PM's about my gauge in the center console, so I decided to post up some info.
It is an Aeroforce Interceptor scanguage from http://www.aeroforcetech.com/ They cost $239 and are presently available for american cars/trucks, and Mazdas.
It plugs into the OBD port under the dash and has no other connections to the car. It is "read only" and does not alter performance in any way. It comes in various colors and can display two parameters onscrean at at a time. It does have a performance meter and shift lights too! If you need more, you can piggyback two gauges, they can be ordered direct online. I am not affiliated with Aeroforce in any way, though I did some prototype testing on the gauge for them.
Here is a list of what it can show:
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Alternator %
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs
Edited by ptcary
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
Moved.
I too was looking through your build and this gauage caught my eye. More money to spend now thanks.
Fuck that ain't no lie.
It kind of works out, mama doesn't want to get rid of the a-pillar for some gauages like I have in the Excursion so this might work.
Yeah, lots of parameters, I assume your X is a turbo-deisel, and if you don't have to buy one for the wifes truck, that saves some money! A lot of the turbo PT owners replaced gauges with this one, maybe do a dual pod, with an aeroforce and run a second manual gauge that you use a lot, or go for two aeroforce!
When you have time, go through their whole website, I think they have the actual owners manual online, and they have a forum to, look in there for any other Ford posts to see waht other truck owners have to say.
I have had mine for almost a year now, and love it!
FYI, it also scans for and can clear OBD trouble codes if you ever have any, it will only display the code, so you still have to look it up online.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
I'm scared to even spend time looking at it. just a brief over view and I was raising it higher on my need to get list. :unsure:
