I am looking for a new amp to run four 12" L7's off of.....how many watts would this amp really push out at 2 ohms....heres the specs of it.....
Brand New POWER ACOUSTIK OV1-5500D 5500 WATT MONO CLASS D AMP NEW
This Item Is Brand New! In Factory Box!! Never Been Opened!!!
Limited Time Offer! Huge Savings!
Brand New Power Acoustik OV1-5500D Class D Mono Block 5500W Gothic Series Amp
Hi Speed Digital Circuitry
Fully Regulated PWM Power Supply
Four Way Protection Circuit
1 Ohm Stable
Bridging Synchronization
Variable Low Pass 50Hz-150Hz
Variable Subsonic Filter 15Hz-40hz
Variable Subwoofer EQ @ 45Hz
Phase Switch 0-180
Remote Dash Mount Low Level Gain Control (Bass Knob) With Cable
Frequency Response: 15Hz to 150hz
S/N Ratio: 100 db
THD: 0.5%
System Distress Indicator
Inputs Sensitivity: 200mv-8v
Dual Mono Speaker Output Connectors
Platinum Plated Heavy Duty Power & Speaker Terminals
1700W RMS x 1 @ 4 Ohms
2500W RMS x 1 @ 2 Ohms
3200W RMS x 1 @ 1 Ohms
5500W MAX x 1 @ 1 Ohms
5x 30A Fuse Rating
Dimensions: 14"w x 2.5"h x 12"d
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
Probably about 1500-2000 watts rms.
**New setup in the works** Shocker sigs ftw!
*Breakin Glass and Kickin Ass*
Team SBC
Team Full Force
Refs
SMD-derrick, Bangin Explorer, Exposport, Bass 14
CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14
cac.org-Spl Guru, Andrew, dblover, lunari
How many watts are you trying to get and at what Ohms, I assume 2 ohms because thats what you said but want to be sure? And how much money do you have to work with?
im tryin to get like 2000 watts at 2 ohms....budget is under 400
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
There is a Orion 2500 for sale for 450obo in the fs section. Check that amp out. Itl put out right around a solid 2000 watts at 2 ohm. And it will blow that pa amp out tha water
Team SBC
Team Full Force
Refs
for the money you cant go to wrong with the pa i had the same 5500 on my 8 15s at 1ohm and it was loud but for a extra 300 i got the mojo 2500 and it was night and day difference, so with that being said it is worth waiting a extra month or however long it takes to buy a quality product like kicker,fosgate,memphis,sundown and orion ect.
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
i agree wit mrwigglezdj if thats absolutely all you have to work with you can look into so different amps but if you CAN get more i would also recommend waiting and getting a better amp
Edited by Forceww
Team SBC
Team Full Force
Refs
but if you have to run pa i would recomend going with the pa 3000d and get 2 and strap them and run at 2 ohms .... be around 25-3200 watts rms at 2
how many watts do you think i will get out of this amp alone? at 2 ohms?
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
