If I Wanted To Upgrade Amps.. (for 25k+ Watts)
Guest Powered By Hate
Stetsom amps arent very efficient.
I wouldnt work with them.
Alotta mixed opinions. Who actually owns multiple 5kw+ amps and run them (maybe not at like .3 but hard) for burps.. and have had success with them. Scuccess = not blowing up. 16v.
No, i have not owned a Stetsom amp. I was going to do a trade for one until I did some research and talked with a friend about them.
This is taken directly from the source...
"You'd be taking a step back, do NOT get one of those amps...they put out a lot of power but in all seriousness at 15% distortion...
The way they do it is a very cheap and effective way to get a lot of power, the problem is the design suffers from reliability standpoint, cone control and everything else suffers greatly.."
Model: 7K2 D
RMS Power @ 13.8V Mono 1 Ohm: 9700 Watts
/ <0,9% THD Mono 2 Ohms: 5800 Watts
Mono 4 Ohms: 3200 Watts
RMS Power @ 12.6V Mono 1 Ohm: 7200 Watts
/ <0,9% THD Mono 2 Ohms: 4800 Watts
Mono 4 Ohms: 2700 Watts
Number of Channels: 1
Minimum input sensitivity: 0,2V
Total Harmonic Distortion: < 0,9 % THD
Signal to Noise: > 90 dB
Subsonic Filter Frequency: 20 to 80Hz
Crossover Frequency LOW PASS: 50 to 8 KHz
Frequency Response: (FULL RANGE) 20 Hz to 8 KHz (-3dB)
Power Tension: 9 to 15V
Consumption with musical signal: 6 to 390 A
Consumption with BASS signal: 6 to 780 A
Dimentions (H X W X L): 70 x 280 x 688 mm
Weight: 10,4 Kg.
That's under audible distortion....
Soo.. soubnds like your friend's full of shit and doesn't know about Stetsom. :rofl:
Model: 7K2 D
Weight: 10,4 Kg.
They also have 16v versions as well right? Even if they put out 8k each i'd be happy with what. 32,000! Thats a big number.. prolly have 10k tied up in amps before its all over though.. plus another gazillion dollars in kinetiks. Ive been reading alot about stetsoms on these forums, keep seeing that name. I should probly start saving once I get my white honda paid off cause as soon as I blow an MA or two.. I'll get into something else if they are habit forming.. heh.
Have you ever used a Stetsom amp? http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.gif
have YOU ever owned a Stetsom amp?
i havent but i know someone who has used them and YES they are VERY innefficient. LOTS of current draw for the ammount of power produced.
your looking like a "know it all" noob again. read specs all you want but first hand experience and knowing someone who actually used them amps and talking to them directly...its a lot more reliable source.
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 1 Anonymous, 2806 Guests (See full list)
